Front fog light bulb replacement mk2
Packard
Looking to swap out the awful fog light bulbs on Auris mk2 touring.
seems to be H16 you tube shows a quick how to guide to remove Trim removal
however not seen many if any posts on hear re suitable bulbs
I’m happy to use leds as they aren’t used that much.
can anyone recommend any ? (That don’t cost a silly amount?)
ideally a cool white to match the main beam PIAAs.
in UK it is illegal to use led bulbs in non led lights on a car. The car can not pass mot and also these conversions often deliver worse performance than original equipment bulbs. You can simply replace your bulb with new and job done, easy and without any hassle.
https://www.ebay.co.uk/itm/234563734138?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=nkcd4eidqsa&sssrc=4429486&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
I am aware of the law
that bulb you have listed is pointless lower power (lumen rating) than the current
so the question is, can anyone offer ideally a “legal “ bulb bit is brighter than the one listed above that it is about as bright  as candle in a storm
if this is not possible, I’m open to those people have used LED bulbs to offer a suitable solution. Thank you
They are supposed to be low wattage (19W)  as they are fog lamps, not driving lamps, anything bright in there will be blinding people, especially LED
You must have very very badly angled fog lights (mark 2 is adjustable) so in NO WAY would they blind anyone even if 1000w
the discussion / post was over the bulb (lumen rating) not the ethics of whether to go brighter whether via traditional non LED or other methods
They are FOG lights, putting anything ultra bright in there is defeating the object, light will bounce back at you and be of no use at all. What are you trying to achieve?
  • Like 3
I just wanted options on better brighter (lumen) and a better kalvin rating than the current dull candle.
It's a H16LL, I don't think you will find a brighter (higher wattage) in that bulb, you might find a colder K range, as the bulb/lamp is not designed to be bright, the headlamps do that
Foglights are only tested on cars beyond march 2018. So auris is exempt, is my understanding.
Exempt is a bad choice of word. They cannot fail you on the MOT for something they should not be testing.
pity we know the headlights truly awful and I was lucky enough to get both full headlights replaced warranty to the slightly better design.
compared to my Honda the distance is night and day literally
ill be avidly hunting to buy a suitable higher K and L rating if I find any I will post for benefit of others
