Main 12v feed for horn relay, where?
Woodie100
Hi all
ive decided to upgrade the rather weak stock horn (more like a whimper than a beep)
I have got a twin air horn to fit which requires a relay but part of the wiring diagram found is a direct live feed to connector pin 30 on the relay, my Battery (2.0 hybrid CHR) is in the boot! Is there an accessible 12v live feed in the engine bay I can spur off?
not looking forward to removing the front bumper either, seems a tad excessive to replace the stock pathetic horn, but can’t use the stock horn as too embarrassed and imho pointless as far to weak.  Really could have benifited from a decent horn this morning when a white van pick up decided to pull off whilst I was passing beside him.  Had to serve and luckily no on coming car.  Van completely unaware that I was there.  If I was on my Bike that’s fitted with twin airhorns he would have had to change his trousers as they are mega loud!!
any suggestions will be gratefully welcomed🙏
JonB
still love the car soooo much! 👏!
Why do you need a relay?  I previously used a relay for headlights to shorten the feed to the headlights and the switch wiring to the relay.
An obvious live feed to the relay is off the fuse box but you don't gain by a relay.
Is it a real air horn with a compressor? What's the current draw?
If they are just normal "snail" horns, chances are the OEM wiring will be fine and you don't need a new feed and relay.
You are not alone 🙂 I know someone who has taken this whole horn thing to a new level and installed twin air horns from a railway locomotive. It's not just that it is LOUD, you feel it in your chest. Quite difficult to ignore.
  • Haha 1
You know PartsKing?? :eek: :king: :laugh:
Toyota horn circuits are simple
what sort of current are the new horns ? You have 8-9 amps on the standard circuit, the standard horn is around 3–4 amps
example
KGB10 horn diagram.pdf
