Avensis 2011 2.0 d4d P2002 Diesel Particulate Filter Effic
avensisd4d786
Does anyone know what the cause could be?
The most common reason for P2002 is a clogged DPF. This can happen due to frequent short trips, not reaching high enough engine temperatures for efficient regeneration, or simply reaching the end of the filter's lifespan
 Faulty sensors monitoring the DPF pressure or differential pressure can also trigger the code, even if the filter itself isn't clogged
Leaks in the exhaust system before the DPF can disrupt the pressure readings and trigger the code. Hope this helps😄
As said above the most likely cause is a blocked DPF.  Try going for a drive on the motorway, keeping the engine above 2000 RPM for at least 30 minutes.  This will cause the DPF to attempt a regeneration, which if successful, should clear the code.
  • Like 3
How do we know the DPf is doing regen as my exhaust is all clear coming out the back and no difference in noise from the engine .my friend knows when his VW group car goes into regen as sounds different
Interested to know this too as I can never tell.
You can't tell when it is completing a regen.  It is just getting the DPF up to a high tempreature to burn off the soot.  I know on some cars like VW, the fan sometimes stays running after shutting the car off to cool the DPF.  I have never heard the Avensis doing this however.
aye my friends vg group car he knows when it is doing it and when he hears it he drives the sht out of it but when comes to my toyota i know nothing . i was wondering if i connect up my toyota techstream or my autel md 808 pro would it  be able to show how blocked the dpf is
  • 4 months later...
Did you solve the issue?
well I'm using Torque Pro and OBD2 on my other car and so far so good.
Now have only to find PID's for my Toyota
Well pic. writtings are in portuguese, sorry, but if you need can translate.
Hope helps you
