Help! I overloaded the boot and broke the clip on the tail gate privacy screen/parcel shelf that is attached to the boot lid. I’ve found the replacement entire screen, but I’m trying to find just the clip with no luck. Does anyone know if you can replace just that part (circled in red on the photo) and, if so, what it is called or where it is available from?
thanks in advance!
You have to buy whole unit unfortunately.
Part 6490402010 cover sub-assy, tonneau, no.2
Will an "engineering solution" not suffice?
Unless the replacement cover is dirt cheap?
Thank you for the replies!
I’ve found a replacement unit on eBay for £60, which doesn’t seem too bad but was hoping it would be much cheaper if I could replace just the part that is broken.
unfortunately it’s not really a fix it situation, the clip broke into several pieces! Looks like it will be the whole thing replaced!
