Can anyone tell me is there a fuse for the top brake light, only the light is wired in, there is no bulb holder, is this correct,  please
Hi Pamela ,In some Estima models, the top brake light, also known as the third brake light, may be integrated directly into the rear spoiler or another housing without a traditional bulb holder. However, there should still be a fuse dedicated to the circuit that powers the third brake light. If you have the owners manual it should be in there.
If not  @flash22 is the best person who can help with the location and size of fuse. Hope this helps😄
brake lights are all wired together so if it was the fuse none of the brake lights would work
81570-28180
81570-28200 Aeras, G and X models
81570-28190 hybrid
if it's the led type it's a sealed unit pull the wire out the car and check for 12v at the plug with the brake pedal pressed
if it's the older bulb type looking at the light there is a black blob in the center this is a bulb also the gray bulb holder sticks out the back
eg.
https://youtu.be/w9vTTcGRC4w?si=kSlkBTcQ3l_MHNng
