Bulb
breezer
Howdy folks!!
How do ya get the passenger side headlight bulb out? coz the Battery is in the way...i got toyota to do it the last time, and a think they took Battery out am not sure.
whats your comments!
ps. oh dear a jus seen a snot green micra go past wit a 4inch exit backbox and a custom spoiler lol :D
headlight?, just remove the air feed pipe (1 bolt) or remove the Battery
saw a blue fiat bravo in salford today, no external mods but it did have a dump valve and the car was rapid
Complete initiation into the dark art of bulb removing:
-take off wiring connector
-take off rubber cover
-push top side of metal clip
-pull up top side of metal clip
-repeat on bottom side of clip
-take out bulb
-put in new bulb in the correct position
-put metal clip back over bulb socket
-put rubber cover back on in the correct position (it's marked)
-put some vaseline in wiring connector
-put wiring connector on in the correct position
alternately check owner's manual
yvvan, it hard to do step 3 & 4 on NS as there is little room, I managed to do it but I had a few scratches on my hand
it is possible but as vmail says its a bit tight on space
I know it's a bit tight down there but there really is no need for removing the Battery or anything else. there are far more tighter spots on a car.
As for a few scratches, consider those your warrior marks :D ,they'll heal, crushed fingers don't.
Cheers, Yves.
my fingerprint has come back from when I burnt it on the car
what are you after bulbs or LED and what colour
LED are approx 4.50
LEDs come as singles 4in1 or 6in1
LEDs look class, but they are not road legal, if the 5-0 see it you will get bummed, so white ones are better
yeh a know dude!! its only gona b for when am at a mates or sumit or hangin out wit sum buddies in cars!! change em back as soon as am goin drivin...so therefore im not gona get pulled!!
soooo where to get em from?
sorry I dont use PM
click on p_msn.gif at the bottom of this post
