Exactly that - simply swap the CTEK between the motorhome starter Battery and the C-HR auxiliary Battery to 'look after' the Battery that is sat in the shed.
20 minutes ago, Big_D said:
You should be able to connect the C-TEK charger to keep the battery charged. The car won’t start on it’s own. This will only happen if you have the car in Ready mode, using the hybrid battery to charge the 12v system. You’ll be fine.
Thanks for the clarification - sounds like a plan 👍
