Blueprint clutch Vs Borg and Beck clutch
Saffy24680
HI everyone, hope everyone is doing well, my auris 1.33 needs a clutch, just wondering if anyone has any experience with the companies above for clutch kits, would anyone recommend one over the other?
Thank you in advanced!
Changed my 1.4 D4D clutch to an AISIN one back in January 2020... So far, so good.
These two maybe very similar or same. Both companies are most likely packaging only and they use different brands parts inside. Blueprint for example if you buy a thermostat from them is likely exactly the same as oem for Japanese cars. , so it is possible to find Aisin clutch inside the blueprint box, or Valeo, LuK, etc.
unless you are doing the job yourself, let the garage supply and fit then they are liable for any problems
  • Like 3
I had a Blueprint clutch fitted two years ago, it judders badly.
I installed Valeo on my old corolla 2016 Ithink, no issues.
For my Auris I can't find any AISIN, LUK or Valeo anywhere at decent price, seems to be short supply.
ECP has AISIN but at £40 more than the original Toyota parts.
