Caliper torque settings.
WOODWAYS6
What is the torque settings for the front caliper.Firstly the two smaller bolts the hold the pads and which can be swung up off the disc .In newton metres please .Thanks.
I can give only the torque specs for the Gen 2.  I'm not sure how, or even if, it relates to a Gen 4.
For the two bolts (14mm head) for the front disc brake cylinder sub-assembly (which I have always known as the caliper), the torque is 34 Nm.
For the two bolts (17mm head) for the front disc brake cylinder mounting bracket (which I know as the caliper bracket), the torque is 109 Nm.
Hopefully, someone with the Gen 4 repair manual will chime in and confirm.
