Toyota Yaris MK2 MultiMode gearbox problems
SteveB 139250
My Toyota Yaris 1.4 D4D with a MMT gearbox recently threw up a red gear icon on the display and would not change gear or move.  I was stuck holding the traffic up and  had to get towed home, the next day the car drove normally but I am wary about driving it now in case it happens again.  Has anyone had similar problems with this gearbox and any idea how I can sort it?
get it scanned for codes its usually a sign that the clutch is on the way out and/or an actuator issue
I have disconnected the Battery and connected the two cables together using a jumper cable.  I left it like this for several hours to reset the ECU to factory settings before re-connecting them.  I have driven the car a few times and it seems to work fine now.  I am still wary if the fault will return, time will tell.  My car is at an age where the cost of taking it to a garage for repair is more than the car is worth.  No local garages seem to want to get involved with auto gearboxes because of the complexity of them.
not many places take on the MMT as it can turn into a can of worms, ending up with both parties being very frustrated and a pelican
It's a tricky one. Buying a used replacement car comes with it's own risks that it will need repairs soon, so sometimes it's a case of "better the devil you know" and fixing it. But the MMT boxes are notoriously iffy, so at 16 years old I'd suggest living with it till it finally gives up and meanwhile start preparing to get something else.
The MK2 MMT will give up the ghost soon, it happened to a relative of mine.
  • 6 months later...
Result - the problem was with the clutch actuator.  I took it off and sent it to ECU Testing via eBay for re-conditioning.  It cost nearly £200 but it has cured my car`s problem and it has worked without fault since it was refitted.  Make sure the electrical connector is securely pushed home when refitting.
  • Like 3
