Cruise control D4D e15
luis espadinha
Boa noite malta dos auris,
alguém pode me facultar a instalação do cruise control da auris 1.4 e15 d4d?Comprei a manete do cruise control e nada fez.
Parece que é necessário uma artimanha qualquer, alguém me pode ajudar?
Agradeço
  Hi Luis !
  I don't think that your Auris ECU is compatible with CC, only 2.0 and 2.2 D4D supports this feature...
Hi Luis,Some Auris models might have cruise control activated via software. You can check if your model is compatible with this option and, if so, take your car to a Toyota dealership for activation. In some cases, an additional module might be necessary for the cruise control to work.  It's important to verify if your car's wiring is prepared for cruise control. If it's not, you'll need to install additional wiring. Hope this helps :smile:
Esquema para adicionar?
Podem arranjar?
Obrigado
The Auris didn't get cruise till 2010/11 some 1ndtv cars required the driver assistance ecu for CC
In short, if the ecu does not have CC it can not be added, and it can not be added/programmed
55 minutes ago, flash22 said:
The Auris didn't get cruise till 2010/11 some 1ndtv ...
...and 4ZZ FE (1.4 petrol) as well.
I should state that is just the 1ndtv that didn't get CC
  Of course mr Bob, but I'm upset that my 4ZZ engine doesn't accept CC. 😞. Sorry for my addition.
Alguem pode me facultar a instalação para montar o CC no meu Auris?
Obrigado
