Basic novice question: Which grade fuel in my 2008 (106000 kilometres) Estima 2.4 Hybrid is best ? 91 or 95 or 98 ?
Will it run on E10 ?
Translated manual merely states "gasoline"...
I alternate between 95 E10 and 97/98 E5.
Runs fine whichever.
I have the petrol 2.4. I used either E10 or E5. It seems to make absolutely no difference but I used the E5 about half the time just to be on the safe side.
I am using Tesco 99E5, 95E10 make MPG worst and noisy engine, this van has a high compression engine, if used 95e10 the engine will produce less power, unless you don't need power, I got 3-5mpg less from 95e10.
