Toyota Space Saver Fits
marlinleg
I Thought  it may help someone Toyota supplied space saver wheel fits into my Yaris Cross Excel  2WD 2024 and the boot adjustable floor works in low and high position please see photos . also I am loving the Yaris Cross. I've check the fuel mpg by filling my tank setting the trip to Zero returning to the same garage pump 255 miles 100 miles motorway 63.8 mpg the cars done just over 1,000 miles  average outside temperature 7/11 c
  • Like 4
Thats really useful, was planning to have a spacesaver in my 2WD Cross instead of the 'shaving foam' its supplied with - was worried it might slide about without some sort of insert, but yours looks pretty tight to the edges of the available space ? -  I I cant see in the pictures, what is the tyre/rim size they have supplied you with ? Thanks
Had mine fitted last week, it came with a styrene insert for the inside of the spare for storing things.  I was a bit worried when I first looked as I couldn't see a jack, but it was hidden in the cubby behind the trim panel on the right hand side of the boot.
Mike I will have look tomorrow get a better picture have a look at this one let me know if you need a photo tomorrow
Mike It won't be any trouble just let me know
@marlinleg I have the MY21 Excel.  Above the wheel is a deck board.  Then at a higher level split deck boards that you appear to have.  What isWheel cardboard for? Do you only have the higher board?
Roy the card board was in my rav4 under the rav4 spare wheel to stop it rattling 😂😂 so I took it with me in case I need it to stop the Yaris's cross spare wheel from rattling 😵‍💫 I am a belt and braces man 😂😂😂😂 it wasn't needed in the Yaris or rav4  in the recycle bin
  • Like 4
Mick ref space saver moving I got supplied with the spare wheel bolt see  photo my original  post it came with it from Toyota no jack. It screws into the thread that's already in boot Tyre size and photo of the adjustable floor low and high setting  . Hope the helps
Great job. I have a slightly different size on my spare T125/70 D17
Great - Many Thanks
And I suspect that the cardboard would come in handy to kneel on if you had to change the wheel in bad weather or a muddy road
Gren at 75yrs 11months and 29 days old i will leave it to the AA 😂😂
In extremis, and lacking foresight, use a footwear carpet.
If you have the rubber boot protector use that.
Better still, and there is plenty of room, a couple of towels to kneel on.  Rubber gloves and wipes.
While I have seen a very well prepared campervan with a trolley jack I like the electric screw or scissor jack kits you can get.
