Hi all got the armrest panel driver side uk lose. Have tighted it. It did become better however should there be a washer and screw to make aight fight?
Hi Rhys, It's unlikely there's a missing washer in your specific case, but  you might be able to tighten the existing screws a bit more. Be careful not to over tighten and strip the threads.
Check for any broken parts sometimes, the plastic around the screw holes can crack or break, making it difficult to achieve a tight fit. You might need to replace the panel or the surrounding trim piece.
If there's a gap around the screw and it seems like a washer would help, you can try using a thin washer made of rubber or plastic.Hope this helps :smile:
Ok thanks. Yeah i take a photo of it and send. Was gonna use a metal washer. But rubber or plastic will be best suited
