Primary driver removal and wireless CarAndroid connection
Hello there
My hb bought me a second hand 2023 C-HR 2.0 Hybrid Team Deutschland a month ago from a dealer in Germany.  We live in Poland.  Is there any way I can remove the primary driver from my car, obviously I don't have his password but his name is there.
I would also like to know if I always have to have my phone (Samsung S22+) connected via USB for the CarAndroid to show on my screen, is it not wireless compatible?
Many thanks in advance
Debora
Probably need to go into a Toyota dealer to remove the old account. Carplay/Auto requires a usb data cable, unless you buy a third party dongle or similar .
Apple car play is wireless in a 2023 model, but you need to connect with a a cable the first time you use it
7 minutes ago, asinrutee said:
apple car play is wireless in a 2023 model, but you need to connect with a a cable the first time you use it
Thanks for the info, I don't have Apple though, I have android only (a Samsung S22+ phone)
Download and check the online Navigation / Multimedia System Manual. I'm pretty sure that you will find a "System reset" function that will "Reset all of the system’s data and restore the settings to the factory defaults."
Alternatively, you may be able to delete a user profile - again check the manual.
Thanks for the help 👍
This wasn’t the case with my iPhone
As for resetting the primary user, there is an option in settings to restore everything to factory settings.
