Alarm Problem
Brian32
Hi wondering if anyone else has had a problem with the standard celica alarm? I own a 2001 190 bhp model and have constant problems with my alarm going off. Also where are the sensors? Is it the bits in the door panels that look like tweeters? Appreciate any help/info you guys can give. Cheers.
Does it have ultrasonic/motion sensors? If it has, have you tried shutting off the outside air vents (set air vents to re-circulate rather than allowing air into the cabin) this worked for me on other cars I have owned.
cheers mate i know nothing about the alarm at all but guessing its ultrasonic/motion sensors, cant even locate the sensors!! Ive tried closing the air vents an will also try setting the recirculate now, hopefully this will work. thanks again.
