Tried look at threads and forums but couldn't find out the handle size or I guess what door the IQ Matches. I know it has prius wing mirror covers, maybe it's the same door?
https://www.amazon.co.uk/Riloer-Protector-Compatible-2018-2022-Hatchback/dp/B0CSSMN1CS/
I was looking at things like this as I want some black covers but can't seem to find anything as I don't know the door type. Anyone found any?
Hi Sam, i assume you have looked at at a number of web sites to find the covers but with no luck. The link for Amazon doesn't mention the iq, but you could try contacting the seller to see if they have ones for your model, obviously quoting your model and year.You could also try Toyota uk and ask them or a Toyota dealer they might have the specifications for the handles and recommend compatible covers.You could also measure the handles width, length, height and search online for similar ones but this might be a bit hit and miss with the fit.
Have you considered stickers for handles they might be worth a look and they are readily available. Link below. Hope this helps :smile:
https://www.amazon.co.uk/Handle-Cover-Stickers-Toyota-Color/dp/B0BZY8WCQ2
Maybe a pair of original painted black doorhandles from scrapyard?
The link the OP highlighted were handle covers for the 4th generation Prius, which was produced 2015 -2022.
As the IQ was produced between 2008-2015, and if it were to use the same handles as the Prius, they would probably be from either the 2nd (2003-2008) or 3rd (2009-2015) generation Prius, rather than the 4th generation (2015-2022).
