Auris Clutch replacement diy
roks
just read this, the easiest way to get the CSC working is to open the bleed nipple and fill it with a syringe (make sure you have some spare room in the res) and this will fill it and it and shouldn't require bleeding, just close the bleed nipple and you should have a working clutch straight away
