2014 Auris front wing replacement
mushrooom
Planked the front wing today and smashed a headlight. With the high mileage I don't want to go through insurance as they'll write it off. Has anyone changed the front wing before? Is it just a bolt on job? Havent had chance to look under the bent bonnet yet
Well after the amazing response to this question I'm not expecting the answer to these either. I swapped out the smashed headlight for my old spare one but I've got a few problems with it.
The shutter for main beam isn't working and it looks like you need to dissassemble the unit to get to the back of the headlight, is that possible ?
Also the DRL on the same headlight only works when the lights are on at night, and not in the day, any ideas ?
Im sure there are a couple of vids on youtube on swapping out the wing and headlight. You may have to search for corolla and "fender", but its identical to auris.
I think you can disassemble the light, again another recent video on youtube where a guy disassembles an LED headlight. Search "toyota maintenance" channel on youtube.
If you cant find them i will have a dig.
I would check pin voltages/fuses before taking apart headlight, just in case you blew a fuse or damaged wiring in the accident.
