A 1991 Toyota Camry will not start
Virginia
I have a 1991 Toyota Camry it was hesitating to take off during acceleration while driving then would let off the gas and press in again and it would take off sometime but then was driving it it cut off and will not start back up and no check engine light is on
Hi Danyl, the problem possibly may be caused by a clogged fuel filter or dirty injectors,these restrict fuel flow, which can lead to hesitation and stalling, especially during acceleration when the engine demands more fuel.
A failing fuel pump may also be the problem as a weak pump wouldn't deliver enough fuel pressure, causing hesitation and potentially stalling.
A clogged fuel filter or dirty injectors typically worsen over time. As they restrict fuel flow more and more, you might notice hesitation initially at higher acceleration demands, then gradually experience it more frequently until eventually the engine can't get enough fuel to run smoothly at all, leading to it stalling.:smile:
A failing fuel pump wouldn't deliver enough fuel pressure to meet the engine's needs. This could cause hesitation, especially during acceleration when more fuel is required. In severe cases, the pump might not deliver enough pressure to keep the engine running at all, leading to it stalling.There may also be other issues that have caused this problem but without any fault codes its difficult to identify.👍
Topic moved to the Camry forum.
