vacuum pump for your brake booster inspection/ halfshaft
hello, i have a toyota rav4 2008, doing some maintenance on it, it has 200k km
manual calls for inspection of the vacuum pump at 195k/10 years .
how exactly are you supposed to test it/inspect it?
also I need to torque the halfshaft bolts, what's the torque on them? should I loosen them and then torque them to spec because of static friction? or should I not touch them since they've never been torqued for 200k?
the halfshaft bolts the manual talks about are the ones I circled in the picture right?
