Tns510 loading kiwi file
mainair
I have the dreaded file cannot be read consult dealer message. The car, avensis estate 2010 with tns510 sat nav/audio head unit. The car is new to me, and without any discs or SD card. I am lead to believe I need a loading file on an SD card. Does anyone have an SD card that I can buy. Thank you
Hi, I also had same problem after disconnecting Battery, but in my case I had original SD card. So you need to borrow or buy sd card with maps.
or you can try as shown in this video
