Had to put a new slave into the 1.6 4af and I’m trying to figure out how much fluid I need to get anyone know?
Not much. But it's cheap and half a litre should be more than enough and allow you to flush through the master as well.
The hydraulic clutch system on the Toyota 4AF engine typically requires around 0.5 to 1 liter of clutch fluid (usually brake fluid). However, it's always best to consult the owner's manual for your specific vehicle.Hope this helps.:smile:
The master reservoir is tiny on these and hold about 1dl / 100ml. With a litre you can do the brakes as well. Which is a good thing! 🙂
