Replacing old radio with touch and go / need help
Dkkz
Hallo to every one , I must say first of all that my English is not very good but and I am sorry for that ( I miss a lot of school classes for English 😄 )
So my problem is that I have a Toyota Avensis from 2009 with standard radio and I wanted to upgrade with sat nav touch and go and OEM reverse camera. Everything is ok but I have problem with wiring the OEM camera to my car and I need a little help about it. What connections I have to do with my car I suppose that I need cable from the camera to the back light and what are other connections and where they go in the navigations I mean which pins I have to connect to be able to start this camera! I wil be great full for your help! Thanks !
well tbh between you and me i would not be changing it to the toyota touch and go 2 headunit as it comes in my car and its nothing but junk. the touch screen pisses me off to gods end and well if i were you i would change it to a pioneer android head unit with dab+ there way class than this touch and go headunit i hate mine its a toture to get around and i am never done hitting the ok button when want to use the phone free feature on the car
Does this help?
Sedan: https://www.toyota-tech.eu/aimuploads/{2552330D-8E6A-7F1D-D9BC-BA8BAE138E6A}/Avensis_Sedan_Back_Camera_PZ473_T3140_00_AIM_001_549_2..pdf
Estate: https://www.toyota-tech.eu/aimuploads/{A10BA4B7-99A5-F725-C930-1E8AB9AA99A5}/Avensis_Wagon_Back_Camera_PZ473_T5140_00_AIM_001_550_2.pdf
He asked instruction about wiring camera not opinion about headunit.
And tbh I haven't had any problems with touch and go headunit.
And tbh those Pioneer etc headunits looks so weird because they doesn't fit anyhow at original place.
And tbh I personally prefer OEM look at headunits.
original Toyota camera works on 6 volts max I used a mobile phone charger for it
and pay close attention to the polarity of the DC voltage.
10 hours ago, JiiN said:
Does this help?
Jiin thank you very much for your response, but I’m not sure that this is for t27 because of the ilustrations I’ve seen there is much more maybe t25!
Also I have installed from a donor car the 28 pin connector for my steering wheel control, so I’ve seen in the guide on tech.eu 20 pin connector showed that the wires going inside this connector but I don’t have anymore this connector, so I’m little bit confused! In the images they show is last four pins I have to put in this 20 pin connector but is it the same with the 28 pin socket! The last four or what ! Thank u!
Vehicle code says T27 but here is newer (2011) one
Sedan: https://www.toyota-tech.eu/aimuploads/bdab5f1b-6d13-40fc-8b9f-5dc7d17ad839/Avensis Sedan Rear Camera Mirror LHD AIM 002 313 1.pdf
Estate: https://www.toyota-tech.eu/aimuploads/13c2455e-c383-4827-a64b-4369cf1f3dcb/Avensis Rear Camera LHD Wagon into Mirror AIM 002 315-0.pdf
I will be happy if some one has done this kind of upgrade and share his experience!
21 hours ago, JiiN said:
JiiN in the guide it is shown a connections with a rear view mirror and I’m not sure this is the correct way for connect the camera? I’m uploading picture of my head unit in the back side if you have any advices il be great full !  Cheers
the RCA plug is the video signal for the camera,
and the wires next to it are the 6 volt power supply,
, and then there is another wire somewhere that carries 12 volts with which you activate the new radio and the camera when you shift into reverse.
Sorry I didn't write it all down correctly, but I still remember this a bit
It does not help me at all! The picture is a mess. Your advices are not specific but thank u!
  • Sad 1
If you look closely at the "messy" photo you will see that 4 wires have been cut, these are the power supply and video signal of the original camera.
I make it work ! Soon I will post a guide for wiring diagram for OEM reverse camera upgrade with this head unit touch and go !
CHEAP Chinese Touch Screen Android Stereo!
Here is a video on just that, and his other videos dose reverse camera
