Hello everyone, my problem is that the left turn signal light on dashboard does not work and sometimes it lights up very dimly. I replaced the left turn signal light in the mirror, the previous one was wet and stopped working.  the right light works well. the hazard warning button does the same. I will add that all the bulbs are flashing well.
Thank you.
it cant be much It is either a fault with the LED on the dash or a connector/wiring issue as the left side is all linked, you can rule out a ground issue as the left and right LEDs on the cluster share the same ground
I would start by unplugging the dash checking the plug and socket then plug and unplug it a few more times (cleans the contacts)
