Good afternoon,
I'm shopping for a clutch kit and was wondering if I should buy a 190mm clutch kit or 200mm clutch kit?
The price is nearly the same but I'm wondering if the 200mm can even fit on a 2006 C1 or if it is only meant for the second generation. Also whether or not it's a smart move/pros and cons. Perhaps a 200 is more durable?
Thank you,
Erik
Originally the Aygo/C1/107 had a 180mm clutch, but from around 2009 the 190mm clutch from the Yaris was fitted.
The 200mm clutch is for the Mk2, as frosty says the original Mk1 clutch was uprated from 180mm to 190mm due to many failures of 180mm clutch in early Mk1 cars. No idea if they altered anything else clutch related in Mk2, but they did redesign/fix many other Mk1 issues with the Mk2, so they may have so it bit of a gamble. Saying that not heard of any further issues regarding the uprated 190mm clutch in the Mk1, so that fix worked.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
