T27 Rear camber
rob42
so it would appear iv a rear camber issue, on inspection the brushes don't look terrible but its a 12 year old car with 310k km on it so problem due a change anyone done this arm before?
You may have to cut the bolts. Even if you get the nuts off, the bolts may be stuck in the arm.
That happened to me and I had to go buy new ones to get the job done.
An induction heater could also be helpful...
cheers will have to look into sourcing bolts so. 👍
