Space saver kit for Yaris Cross
Michael White
How easy is it to fit space saver wheel kit  to 2023 Yaris Cross. Dealership quoted £60 to fit .
The only difficult bit is fitting the rubber band that holds the jack behind the removable plastic panel on the right hand side in the boot.
It is very possible to do it DIY but it will take about an hour and requires some stretching. The dealer charge is for 1 hour's labour and is reasonable, especially as you do not have to figure out fitting the rubber band mentioned by Chas G.
Have a search for previous threads, There are at least 2.
I would agree with that...
@Michael White Also, check out this part of my own topic here ...
Good photos, particularly of the rubber band and the orientation of the styrene moulding. 👍
  • Like 3
Thanks Chas , very helpful.
