I took that cover off, not very professionally but what I see underneath disturbs me a little bit. I'll put a pic on here when my new clips arrived cos I don't want to take it off again ATM.
Anyway while looking into the engine from the front, on the passenger side, there is a hole where one of the plastic clips goes into. This hole is in a metal bracket and the metal bracket paint is all bubbled, I reckon cos there is rust underneath the paint. It does not look like the cover was rubbing against the bracket because all the blue paint is still there. No-one would ever notice this unless they were replacing something on the front of the car. Surely this should not be, and could tis be a warranty claim against the paintwork?
If not waranty claim then I will have to scrape it when the cover is off again, and put kurust on it and then paint it with a thick paint, or even push a foam piece between the plastic cover and the bracket,but as I said, it didn't look like it was rubbing.
  • Sad 1
The paint and surface rust warranty is 3 years from first registration, so 2020 car would be outside the warranty.
  • Like 3
Hi Michael, it sounds like a warranty issue for rust. With the amount of problems you have posted with this car I am surprised you haven't taken it back and asked for you money back. Its only 2020 and you should not have had so many problems.:sad:
Oh for pity's sake.
Anyone that's got the clip remover should check under their car's cover in case of rust there too.
What do you like about the car?
It's a Toyota. I am hoping it's so reliable that'll be the last car I ever buy before I shuffle off :)
Who'd have thunk it, had to wait for new clips to arrive before I could take it off, but turns out the code is 53289-02070 (532802070)
I glued it with CT1 and gaffer tape. I'll see how that works out before buying a new one.
