Mk1Clunking noise when on sharp lock from rear when parking
Hi I have a ml1 rav 4 automatic which is clunking from the rear when turning sharp to park anyone any ideas , car has full service records and 71000 miles to
Hi Charles, unfortunately there can be a number of potential issues that can cause this.The clunking noise you're experiencing when turning sharply could be due to various factors.This can be worn out rear differential mounts, damaged suspension bushings, or issues with the CV joints. Others may include worn out sway bar links, loose or damaged suspension bolts, or problems with the exhaust system, such as loose heat shields. IMO unless you are able to investigate these yourself it is probably better to have a mechanic to accurately diagnose the issue,It is difficult to diagnose without the right equipment.:smile:
