Oil pressure range 1.6 D-4D
solid5nake
Just a quick one guys, I'm trying to find the recommended oil pressure range (warm idle) for a 2016 Auris 1.6 D-4D (BMW engine). Can anyone point me in the right direction?
Hi Harry, the recommended oil pressure range typically falls between 1.5 to 2.5 bar (or approximately 22 to 36 psi).if you have your vehicle's manual it should specify this.Hope this helps.:smile:
Thank you for your prompt response Bob! I really appreciate it!
