Hello
On a toyota aygo 1kr-fe engine
I am posting to you 2 pics one of the current situation and one from the manual I found online
Q1 - which is the correct marking?
Q2 - my timing gear mark and crankshaft gear do not align as shown on the manual
Q3 - did the crankshaft gear rotate by itself?
What I have done so far
The car was very weak and high fuel consumption so
Pistons removed cleaned as well as cylinder head, valve lapped, lifters turning by hand
I have replaced the chain set
Engine rotated 10 times and none abnormal noises heard
Once engine fired after general clean 1 cylinder misfired and the camshaft solenoid alarm 0011 appeared
so I double checked
different spark plugs
Spark plug coils swap and removal while engine running
Air filter
Petrol injector to atomize
Compression ( 14,5 13,2 15 ) bars
All oil holes clean
Vvti solenoid clean and functional
Volt resistance all ok
Chain tensioner ok
Now I have disassembled the timing chain cover again
My thought is that the crankshaft gear has rotated and as a result the rpm - postion sensor is reading false althought timing is correct
But I haven't seen a new engine or a new crankshaft gear position
First time in the forum have been making research for a week everywhere on the topic and yet no solution
you have timed it incorrectly
you set the coloured chain links to the marks on the pullies in relation to tdc
1kr INSTALL CHAIN SUB.doc
turn it over by hand making sure all 3 marks and coloured links line back up
did you replace the crank sprocket ? iirc there are 2 types
edit. did you put the key back in the crank for the sprocket ?
Flash 22
My timing is similar to your instructions
And I have understood so far by comparing 30 videos of this procedure
That there are two types of crankshaft - timing sprocket and the main instruction book has two versions withouth mentioning a difference for the 1kr fe
After rotating chain a whole 5 rounds of 360° the 3 markings align as mentioned to ur guide
Yes I did put back the key to the timing sprocket
Then I haven't replaced the timing sprocket
I will definitely look up for the 2 types
Tsikis007
If I have understood correctly the crankshaft gear is assembled by heating up by the factory producing the crankshaft as I wanted to purchase one as a backup before removing it and it comes already as a one piece with the crankshaft
I will post tomorrow as I have reassembled again today and waiting for gasket sealant to dry
Also additionally I found the oil control filter very dirty and almost blocked
Will try to start engine without it
a blocked ocv and/or filter will throw out the timing it will also generate codes that cause misfires and the engine will run rough and or die when slowing down after the use of 50% throttle or more (intake camshaft stays too far advanced)
check the resistance of the OCV
Yes the crankshaft reluctor is press fit to the crankshaft it does not move - newer crankshafts do not fit the older cars as the reluctors are different, the Aygo, Yaris and IQ all use different variations of the 1KR
Many thanks for the clarification regarding crankshaft gear and actual timing mark
Here is the start up
https://youtu.be/cviDcBwP62s?si=gZrV0aAHYVxqu8fn
Here is the ocv location in case anyone needs it
also found a piece of metal at the solenoid vvt and removed it
So far drove 50km and all ok
