Apperently my 2024 awd would need something like
y = (100 - x) * 70.4 * 1.15
in kwh to charge back up to 100%, x being the SOC (state of charge) to start with in a fraction between 0 to 100 (percent)
This was observed from 30-80% SOC at temperatures slightly above freezing to some 10 degrees Celcius using my home 11kw Easee box
It may sugges the full nominel (beyound usable) capacity of the Battery is at play with a charge overhead/loss for heating at around 15% - or that the overhead for heating battery/cabin is bigger still
During summer it may be possible to make a better assessment of the overhead/loss since less heating up would be expected
So please take this indicational only at this point. I am of course also only guessing the capacity at play but lowering it would make the overhead even larger
Using that figure the cost of energy running my bz on average is 22.7 kwh per 100 kms, or 4.4km/kwh on the first 3000 kms on relatively flat landscape with quite a fraction of motorways. For me that equals so far an average 0.02 EUR/GBP per km or 15% of my former diesel cost for the fuel 🤑 Energy pricing may be even lower up ahead (due to summer, for instance)
As BEV's are in every aspect cheaper (buy, loans, insurance, taxes, service) or a lot cheaper (energy) compared to fossils at my place is seems quite hard to regret my crossing-over 🥳
The bz's own suggestion is a range of 311 kms with A/C, 358 kms without. Practices suggest around 300 kms with my circumstances up to 130kms/h where feasible. Keeping it below 110kms/h may be a better fit to the range model used by the bz from where I see it
Since I got rid of 3 elder fossiles (one as the toy and spare when one of the others had a defect), I'm still looking into the better option for another BEV - having the awd-exec or solterra touring on the radar (current one an awd-prestige), or try out an eqa-amg-350 since there is quite an offer for a 12month lease on that on now, making finances on the same levels, even if consumption may be larger (the least part of things, obviously)
Hi Henrik,it would be interesting to continue monitoring charging efficiency across different temperatures and driving styles.Warmer weather might improve overall efficiency, potentially leading to slightly increased range.:smile:
Hm, the formula needs adjustment - now it just consumed 53.7kwh instead of 64.8 from 20-100% - difference possibly from a warmer Battery from more recent drive and warmer weather
Currently it looks more like
y = (100 - x) * 65 * 1.12
at 10-20 degrees celcius from about half empty to  full
Just landed home at 2% and charged it up fully immediately using only 62.9kwh - implying that full load no waste is at 64.2kwh. Thus I suspect some Battery degrade happened already - perhabs quite some if the 1.12 factor of the formula is still valid around 20 degree Celcius - not exactly sure what to think of it
Btw - it can go at least 160kms/h - above 171 on its somewhat optimistic meter. Location was on a fit (almost empty) german free speed piece of autobahn
Average for the 805 kms trip was 4.66kms/kwh, which did include a lot of autobahn some of it with 'stau'
Fast charge worked nicely, averaged at 109kw/h from 13-60%, peak was seen above 130kw but dropping quite some above 60%, average from 11-80% was just below 80kw/h
A month worth of subsription-fee to get some decent pricing pays itself back with the first 30kwh loaded with Ionity, and their chargers apper evenly distributed on our route.
Still very happy with the bZ - waiting for the second one in a few weeks, same specs different colour. I know, all eggs in the same basket can be a higher risk, but I have faith in youta here 😎
I give up on understanding the battery-management-system at play
Just charged from 88-100% with charger consumption at 10.3kwh for it, this exceeded any prior formula suggested. It that was 12% then 100% would be 85.8kwh 🤪 Temperature around 20 celcuis
Will keep an eye on it just for cost follow-up onwards 🤓
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
