Celica MK5 ST182 (47900-20020 Brake Load Sensing Valve ASSY)
CanaanT
I have a brake leak on the back left coming from the brake load sensing valve.
I can't seem to find anybody with one, or any aftermarket ones.
I know they have been discontinued but wondered if anyone had a work around or knew of a supplier?
Any help would be greatly appreciated.
Thankyou.
The brake tubes that connect to that valve are known to corrode and cause leaks. The last few inches of the tube are not protected like the rest of the brake line. Double-check before you go any further.
