Depo headlamp assembly for 2014 Auris
mushrooom
Picked one up the other day as my DRLs and high beam shutter not working.
The Depo doesn't come with height adjustment motor, just a manual adjuster
So I managed to pulled the manual adjuster out but the motor is a pig to swap over, anyone done one before with some advice ?
The plastic "receiver" on the headlamp unit is really hard plastic, I had to use pliers to get the metal adjuster out
I wouldnt tamper with the depo pattern part. Its likely the toyota electrical adjuster wont be to the same physical spec as the depo manual adjuster.
There's instructions with the Depo telling you how to do it. It's just that the plastic is pretty inflexible.
The motor fits in the headlight no problem
