Help! On my old C-HR I could easily access my trip readings and reset them using a button on the steering wheel, how do I do the same on my new 2024 C-HR GR Sport?  For the life of me I cannot find how to quickly access and reset either of the two trips (although I have found how to set each up for average speed, distance and/or total time)?
I know EXACTLY how you feel ☹️. The Combimeter is great BUT a lot of stuff is buried. Two weeks in I’m still not 100% confident I can find what I want. I downloaded the user manual and saved it in PDF reader which helps a lot when navigating it and finding things. The Trip meters are on P114. Despite having to spend many hours sat on the drive playing around with settings I’m absolutely loving the new car, which is a big step up from the old model , marmite looks  an all 😍
I saw this in the manual and was confused by what is meant by "2 items".
So to quickly get access to my two Trips I have to go into Settings, select Meters and then Trip A and Trip B to view/reset?
Much easier on the old model!
You can set them up in one of the screen views  , you then can scroll through using the left hand control on the steering wheel. To reset you hold the OK button whilst either Trip A or B is visible. It was much easier on the old model and more intuitive but you had far less choice.  It’s just a matter of spending the time to get used to the options.  Once you know where things are it’s no harder than the old model. The ACC controls are now way better on the steering wheel than a stalk hidden behind the wheel and very intuitive so it’s swings and roundabouts 🤷‍♂️
Thanks for this. It seems like to access Trip A and B easily, I’ll have to remove one of the screen default views I already find useful. On the left I have the MPG since last re-fuel and on the right I have the diagram showing where the drive is coming from. Using the default Sport display, can I change the middle display from Settings to Trip, keeping the other displays I already have?
That may be the case 🤔 I think it would be possible to have a one of the 3 views set up with trip A on one side and Trip B on the other side so you could see them at the same time 🤔
I can't figure out how to leave the radio on when I switch off the engine in my GR.
I had a loaner GR and the radio would stay on and switch off when exiting the car.
