Camry 2005 vibrations
Luis9718
Hi. I bought a Camry 2005 it was running smooth but right now has a problem that I cannot find.
it runs well but after 50 mph it starts to vibrate if I stop accelerating the vibration intensities.
i already made a wheel balance and it was smooth for a while but the vibration returned
sometimes the ride is smooth and I don’t have vibration, some days it starts right away, other times it starts vibrating I stop aside turn off the engine wait for 1-2 minutes start again and I don’t have any vibration. I feel the vibration on the steering wheel and sometimes in low speed at the gas pedal.
I have a check engine regarding the evap system (p0441, p0446, p0455)
I don’t know if this vibration is due a problem on the engine or something wrong with the wheels.
thank you
As how you describe the situation it might be from the engine. , misfire or pre ignition. You need to double check that, first to try is premium fuel or additives on the fuel.
Another possibility are brakes. If any of the callipers got stuck will cause drag on the pads against the disc and cause vibrations and overheating. You need to check temperatures on each wheel after driving for some time.
Engine mounts- this is another one that can be bad.
Inner drive shafts - this is also possible source of vibrations.
I recently changed the caliper on the driver side and it feels good, brakes good, doesn’t smell like burn and I don’t feel lost of power.
I’ll check the engine thank you for your advice.
