Evening everyone. I have a familiar problem with my 2010 1.0 iq. 3 warming lamps are on on the dash so I did a code read and it indicated a P2196 and message below.
02 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 1
If anyone can point me in the right direction of which oxy sensor to order it would be much appreciated. TIA
Hi Ted,a P2196 code indicates that the oxygen sensor in your iQ is reporting a signal that is biased or stuck rich.This code refers to Bank 1 Sensor 1, which is the upstream pre-catalytic converter, oxygen sensor on the side of the engine with cylinder 1. Bank 1 Sensor 1 is the oxygen sensor located before the catalytic converter on the exhaust manifold or pipe on the side where cylinder 1 is located. In most 4 cylinder engines, this is the sensor closest to the engine, typically in or near the exhaust manifold.Make sure of the new sensor compatibility. Hope this helps.:smile:
