Does anyone know how to reset the service interval? There are videos on youtube, but these are for American spec cars. Mine doesn't have 'maintenance' in the vehicle settings menu. Thanks.
Hi John, this is the instructions for the service reset that I came across online.Hope this helps.🙂
Turn the ignition to ON press the start button twice without pressing the brake pedal) so that the instrument cluster lights up. Do not start the engine.
Navigate to the main menu on the instrument cluster using the arrow buttons on the steering wheel.
Select the gear icon (Settings menu).
Scroll down and select "Vehicle Settings".
Select "Scheduled Maintenance".Select "Reset". Confirm your selection by pressing "Yes".
This should reset the service interval. If your model doesn't exactly match these steps, you can try the following alternate method:
Turn the ignition to ON (without starting the engine).
Press the back arrow button on the steering wheel to return to the main menu.
Scroll to the right using the arrow buttons on the steering wheel until you reach the "Settings" screen.
Select "Meter Settings", then press and hold the OK button on the steering wheel until a maintenance reset option appears.
Select "Yes" to confirm the reset.
These steps should work for most UK-spec Toyota RAV4 models from 2023. If the steps above don't apply to your specific vehicle, it might be best to consult the owner's manual or contact a Toyota dealership for precise instructions.
Thanks very much for that. Unfortunately, both of those failed at the last hurdle - still no mention of maintenance.
Hi John,is there not any of this under the vehicle settings.
Vehicle Settings”. Then press
and hold OK.
3 Press UP or DOWN of the meter
control switches and select
“Scheduled Maintenance”. Then
press OK.
4 Select “Yes” and press OK.
