Battery warning light is faintly glowing. Car is charging, voltage stationery 12.5 up to 14.5 when moving. Belt is tight.
Battery has been changed to no effect. All electrical items are working OK.
When right turn indicator is activated the Battery light flashes but not when left turn activated.
Any suggestions please
  • Sad 1
Stationary voltage is to low, should be over 14.
Thanks for your response. I’ve rechecked the voltage
Ingnition on,engine off, 12.5
Engine started - stationery 14.1-2
Engine 2000 revs 14.3
stationary, engine idle, with lights AC on 13.9
not professional volt meter
That sounds normal, did youbtry to clean the negative cables on the Battery and other grounding points under the hood?
 the Battery warning light has now gone off without any intervention
Baffled 🤔
