Hi, just bought 64 plate Aygo, tyre pressure light on. Door indicates 33psi, topped tyres up and drove a few miles but light still on. Tried turning on and off ignition. Any ideas? Thanks
Reset switch in top corner inside glovebox. Press and hold til the warning light flashes 3 times
Thanks, that worked!
Sorry to state the obvious, but have you checked the pressures with a tyre pressure gauge?
Previous help from here told me to reset my friend's Aygo tpms by pressing the button in the glovebox which worked after adjusting the tyre pressures.
The reset button in glove box worked. I checked all pressures at garage.
