Hi, I need to replace the broken rear light on my IQ. Does anyone know how to remove it?
From what I can see, it looks like there are two screws holding it in place, but one of them is underneath the black plastic trim and is very difficult to access. How do I remove this trim?
pop the rear boot trim and the rear 1/4 trim
Thank you. Do I need to unscrew anything, or just pry it out? I don't want to break anything.
The rear light is fixed with 3 nuts. The middle one is hard to see.. but its there.
You need long 10mm socket to unscrew the nuts. Dont let them drop!
ok, I managed. Apart from 3 nuts I also had to unscrew one side of the bumper to remove the light.
