I need to replace the CIG fuse. I know the fusebox is in the passenger footwell, and I have levered-off the plastic cover to reveal the wiring harness, but the fusebox is above the hole. I can remove the fusebox cover but access to the fuses seems perversely difficult. Am I missing something obvious? Thanks.
Have you removed the panel that the glove box attaches too, if you give this a gentle pull it should unclip it, if I remember correctly, there is one screw on the bottom left that you need to remove, I think you get to that by removing the panel you have already taken off.
Thanks Steve! That makes things easier. Still difficult to get at the fuses so I'm wondering if the bolt beneath the fusebox will permit me to remove the box for easier access. Is this right or do I have to work upside down?
I just worked upside down
Thanks.
Job done thanks Steve.
