Avensis T22 Fuelpump
Lauri Kauppinen
i think my fuel pump went bad. I checked the fuse and even replaced it with a new one. Is there a Fuel pump relay somewhere in the car i cant find it anywhere.
I'm in the same as you, my avensis 2001 d4d (old model) has a fuel pump issue (diagnosis made by the mechanic) ,it won't speed further 2500rpm, never replaced scv valves, so I'm not sure about the fuel pump itself or something else (relay etc?)
Have you tried taking glovebox off and checking there? I think some Avensis trims have it located there but not 100% sure sorry.
