Air con
Discodave777
Hi all ,, I have a 98 avensis .. the air con compressor doesn’t switch on at all , although the button lights up when pressed . Is it the fuse ? If so where is it ?? It’s not under the bonnet , or drivers side fuse box . Can’t find the “” passenger side one ?? Where is the fuse ? Or does it need re gassing ? It’s an old car & probably has no gas . Bit it would be good to know exactly where the fuse is . Many thx
Most likely just out of gas. It will automatically disable the compressor when the pressure is too low.
  • Like 3
