2005 Avensis Flywheel
TerranceTF
Hi all,
The clutch on my 2005 Avensis recently started showing signs of failing. At the same time as replacing the clutch I would like to replace the flywheel as well but cannot find anywhere that sells them, any help would be appreciated on this.
The engine code is 1AZ-FSE
Thank you for your help
