Washer jets not spraying
Mo_h
2008 Yaris. Washer jets not spraying. Reservoir topped up. Can see water dribbling out the jet but not spraying. Cleaned it and everything. Still not coming out? Can hear the pump working so not sure if it needs changing or if it's something else? Any ideas?
Disconnect the hose from the jets and then try the pump.
If there is enough water out of the open hose it's blocked jets, If not then it's either blocked/ kinked hose line or the pump.
Or non return valve blocked (not far from jets)
Very likely a blocked jet nozzle - Dad's Verso had this where it was only spraying 1 jet instead of two, and I had to remove the jet and blow down it with a can of compressed air repeatedly until whatever had gotten stuck in it was dislodged
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
