Fuel Gauge not going down
Juedan2011
Hi
I've just bought a used Yaris hybrid on a 21 plate and filled the tank up with petrol and driven about 80 miles and the gauge hasn't gone down.
Still showing 8 blue bars.
The miles to go to fill up correspond with the miles I've done but the fuel gauge isn't dropping.
This is my first hybrid and I'm currently on 78mpg
It had 2 bars when I got the car and then filled it up about a week ago.
Is there an issue or does it move after so many miles?
36 minutes ago, Juedan2011 said:
Hi
I think you will find it takes more than 80 miles for the first bar to disappear from the fuel gauge
It does the same thing on my Prius
  • Like 5
Yep, it's the same with most cars
I can do 100 miles before the gauge drops 1 bar after that it goes down much quicker.
  • Like 7
All depends on the shape of your petrol tank.
Same here
Congratulations on purchasing a MK4 Yaris hybrid, it's a fantastic car. You might have purchase a secret special edition one where fuel is unlimited 😁, just kidding, what everyone else said above 🙃
  • Haha 7
It's normal - In most Toyotas with the digital fuel gauge instead of analogue dial, you can do over 100miles before the first block disappears, but sadly the rest tend to go faster after that.
It's partly because the tanks are slightly V-shaped but the fuel senders (*still*) haven't been calibrated to take this into account as they just read how high the fuel level is in the tank and not actually how much fuel is left.
That said the newer ones aren't as bad as some of the older models (In my old Mk2 Yaris, the first 2 blocks really represented half the tank, and the other 6 the remaining half!! :eek: )
  • Like 5
It's such an easy thing to do these days that I think it's deliberate. Makes sense as the time to catch people's attention is when the tank is nearer empty than full. (The low light is the "Wake up you dozy half-wit" point.)
  • Haha 3
It's the same in my Corolla.  Perfectly normal.
Thank you all I'll see if it drops anytime soon since I'm close to 100 miles 👍
Came from a nissan juke where the bars moved more or less instantly
Interesting about the shape of the fuel tank
You’d need some fancy electronics to calibrate a plastic float on the end of a bit of welding rod to compensate for the shape of a plastic tank moulded to the shape of a floorpan, stop it Cyker.
julie.  It’s using the fuel in the neck and the top of the tank before it begins to show on your gauge.  It gives the impossible impression that one half is bigger than the other but it’s normal.  The gauge is only a guide and things get a bit more exciting as you get nearer the empty mark.  Don’t be concerned about it.
Posh name for Renault Crapture.   Hallelujah, you’ve seen the light!
  • Haha 2
Great, just thought there was something wrong
Just got the car and rounded up to the next £1 when I heard the 'click' so thought I'd got the float stuck 😜
Ha yes I have 😆 first time in an automatic too after driving manual for 30 years
Love it ..sold as soon as I test drove the Yaris.
Love the score at the end of a drive too 👍
  • Like 3
Lots of reasons why you should not refuel beyond the first click.   I have forgotten apart from dont do it.  Someone here will explain.
Exactly as I found with the 2010 Auris:
In fact a couple of weeks ago I pushed that to around 180 miles for the first bar to go out. Eeeeh 🙂
These days its purely a software thing, they can calibrate it how they like. I think even the old Carina II and Carina E with its analogue gauge were well on the way to being like this. You could drive for miles before it moved and a full tank always put the gauge a way over the full mark.
An early Audi A4 with analogue gauge is the one car I've had where the gauge was as near 100% linear as you could get. It began to drop with as few as 15 miles from full but was impressive in its linearity. You knew almost to the litre at any point from empty to full how much you would get in the tank. If you accounted for parallax error reading the needle it was dead on 1/1 when full and with a 60? litre tank if it was dead on 1/4 you got exactly 45 litres in. Same accuracy at any point over the full range.
Toyota gauges seem more logarithmic than linear to me.
  • Like 3
Yeah I think I've seen on another thread 👍 1st click it is then regardless of the pennies on the end 😆
Not wishing to contracept but I don’t think that applies any more as they’ve protected against it.  If it does, mine’s ruined because I always eke out the last drop before it dribbles out of the filler to gain maximum range.
  • Haha 3
That's a long time in manuals. I'm about 50% each on manual and auto, which is over 20 years in total. Auto all the way now.
I think the Car Care Nut had something on this.
How much more fuel do you up in after the first click?
Fixed or not, I don't know.
On Google there are lots of advice similar to that below:
If you ignore the first click you could be filling past the top of the fuel tank port, and that extra fuel will end up running into the small drain under the entry and onto the ground beneath your vehicle. “On some pumps the extra fuel may be sucked back into the pipe.3 Oct 2022
The bottom line is that topping off your car is dangerous to you and your car, and may cause problems. Your best bet is to stop pumping when the fuel pump clicks off.2 Oct 2023
  • Confused 1
Ooh, I just round to the nearest pound....not the next £10 😆 scared it will come out over me shoes 😜
  • Haha 2
Oooh 🤔
Yeah and driven a lot of cars over those years and some white vans 😆
First ever time on manual and I love it. .so much easier ..the car drives itself
Loved the dodgems when I was younger ...just turn the wheel and let it down its own thing ..and even more with the safety lane assist thingy ...who needs a Tesla when you got a Toyota 😆
