Engine cranks but no start b2799 code
danyalkhan
Hi there, i have a mk2 yaris 1.0 litre that i bought and has come with an issue where it doesnt start. The car cranks but doesnt turn over. Code reader has gone on and come with 2 codes a crank sensor code and the b2799 immobiliser code. I have changed the crank sensor and still no success, i have taken the dash out and exposed the immobaliser in hopes that i could get it deleted however i have found out that is apparently impossible. Any ideas on how i could fix it in the cheapest possible way.
first off check the chip is inside the key
have a look at page 6
try putting the key in the ignition and push the key up as you turn it
@flash22
Thanks for the reply, i have read that topic and it seems that they are for spare keys, i purchased the vehicle with 1 key, and the remote locking works but the car doesnt start. Would you suggest me buying another key and trying to program that in?
make sure the key has its immobiliser chip inside, the immobiliser and remote locking are 2 different systems
The next steps depend if you know how to use a multimeter to measure powers and grounds
what does your vin start with - VNK or JT
edit. take the key to a decent locksmith's (not timpsons) and see if they can read the key
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
