do i just need to change the g/box oil or is it a sympton of something worse?
MR2 gear boxes are prone to worn synchros which is what causes the clunky feel. You could try using Redline MT90 gearbox fluid which will apparently help reduce that clunkiness
yup changing to a decent oil will help a lot :thumbsup:
I have clunky gears (mainly 2nd though) so i put redline mt90 in and it made no difference at all :crybaby:
when it happens though, it goes into gear fine with no resistance and the sound (the clunk) appears as though its coming from the gear stick itself :huh: is that how it is for you guys??
i get that too but only in 3rd and when its cold, would love to hear what it is
Try these. Probably not the problem but worthwhile. BUSHES :thumbsup:
i thought about getting one of them trd short shifter things to see if that got rid of the clunk?
Worth a try i guess.Think theres one for sale on good ol eBay at the mo. Also you might like to consider TRD uprated gearbox mounts. Available from Fensport.
3rd gear is the worst on mine when cold as well
I like the clunk noise as you change gears, kinda fast and furious stylee :D :thumbsup:
My 3rd gear is clunky, not too bad changing up but changing down from 4th it sounds awful. Mine's supposed to be covered by warranty.
It's the syncro's .. and a short shift will only amplify the issue ..
use good oil and save for a new box ..
it cant be the syncros, its more like a clunk sound that comes below gear knob, surely the syncros would make more of a grinding sound? and i only get it when changing up the gears but never changing down.
mr2's especially turbos are known to have clunky gearboxes.... I like it... :)
